threaded holes in my new headers?
Posted: Mon Mar 02, 2015 9:38 pm
by Pablo The Squirrel
So, I bought these new headers on the internet. they have these threaded holes in them (pictured above) which my original did not have.
My original had a hole in it, that's why I needed a new one
but not threaded....
Any ideas?
Re: threaded holes in my new headers?
Posted: Mon Mar 02, 2015 10:26 pm
by paso750
some headers had connections for a gas analyzer.
The thread should be a R1/8 (conical).
The old plugs were #000047113 (now 78010091A). Not sure if #78010071A is the same.
Posted: Tue Mar 03, 2015 5:32 pm
by paso750
my header
Posted: Fri Mar 13, 2015 7:46 pm
thanks. conical thread huh... the things you learn...
Posted: Wed Mar 18, 2015 1:34 am
and thanks for the part number. The local dealer had them in stock.
Posted: Wed Mar 18, 2015 9:35 am
by paso750
got the washers, too? Applying some anti-seize is recommended.
Posted: Sat Mar 28, 2015 10:11 am
paso750 wrote:got the washers, too? Applying some anti-seize is recommended.
I was wondering about washers. are they special? or would the right size washer do?
Posted: Sat Mar 28, 2015 10:48 am
by paso750
use a copper washer
Posted: Sat Apr 11, 2015 9:43 pm
paso750 wrote:use a copper washer
can't find copper. will brass work do you think? the plugs are brass
Posted: Thu Apr 16, 2015 10:09 am
by paso750
that should be ok, too. It should just be a washer that also can seal.
Posted: Thu Apr 16, 2015 10:01 pm
by higgy
aluminum will work and are readily available
Posted: Mon Apr 27, 2015 2:44 am
paso750 wrote:that should be ok, too. It should just be a washer that also can seal.
I don't understand "that can seal"
Posted: Mon Apr 27, 2015 9:22 am
by paso750
you want that bolt to sit airtight so you use a washer made out of a softer material than steel
Posted: Mon Apr 27, 2015 11:26 am
paso750 wrote:you want that bolt to sit airtight so you use a washer made out of a softer material than steel
