threaded holes in my new headers?
Pablo The Squirrel
Post by Pablo The Squirrel »
So, I bought these new headers on the internet. they have these threaded holes in them (pictured above) which my original did not have.
My original had a hole in it, that's why I needed a new one :) but not threaded....
Any ideas?
Re: threaded holes in my new headers?
some headers had connections for a gas analyzer.
The thread should be a R1/8 (conical).
The old plugs were #000047113 (now 78010091A). Not sure if #78010071A is the same.
my header
Pablo The Squirrel
thanks. conical thread huh... the things you learn...
Pablo The Squirrel
and thanks for the part number. The local dealer had them in stock. :D
got the washers, too? Applying some anti-seize is recommended.
Pablo The Squirrel
paso750 wrote:got the washers, too? Applying some anti-seize is recommended.
I was wondering about washers. are they special? or would the right size washer do?
use a copper washer
Pablo The Squirrel
paso750 wrote:use a copper washer
can't find copper. will brass work do you think? the plugs are brass
that should be ok, too. It should just be a washer that also can seal.
aluminum will work and are readily available
Pablo The Squirrel
paso750 wrote:that should be ok, too. It should just be a washer that also can seal.
I don't understand "that can seal"
you want that bolt to sit airtight so you use a washer made out of a softer material than steel
Pablo The Squirrel
paso750 wrote:you want that bolt to sit airtight so you use a washer made out of a softer material than steel
