EFI rubber dampers
EFI rubber dampers
Any alternative source for the EFI rubber dampers?
nickta
Re: EFI rubber dampers
Post by nickta »
Hi Francesco.
Which one's? The airbox end or the inlet manifold? Or something else?
Cheers.
Nick.
The ones down to the ECU. The same are on the plate that supports the relays etc. on the left of the front fairing.
Mine are broken.
I got some from McMaster Carr. They are called Neoprene Vibration Damping Sandwich Mount, Male/Male, M6 Thread, 1/2" High, 1" Wide
I think in your area http://www.wdsltd.co.uk/product/4070/an ... ed-wds-716
or http://www.misumi-europe.com/en/
should be able to supply what you need
englishstiv
Post by englishstiv »
As temporary fix cut a piece of fuel pipe to size and pass a nut and bolt through it, simple but it works and costs pennies.
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
the silent blocks for the ECU are rather soft compared to standard ones
Many thanks everybody :thumbup: :thumbup: :thumbup:
