Hello. I have a 1987 750 Paso that I bought a few months ago. It only has 3,300 miles and ran and shifted fine but had a leak in the clutch master cylinder. I replaced that but the clutch wouldn't engage so my mechanic told me something was wrong with the slave cylinder and that the previous owner had put automatic transmission fluid in the clutch resevoir. I got a used slave cylinder out of Eastern Europe and a new slave cylinder seal. The Ducati shop put it all back together but still could not get any clutch pressure and they don't know why. So the bike sits and summer is moving on. Does anyone know what I should do???
Thank you.
Clutch Issue
900streetfighter
Re: Clutch Issue
Try bleeding from master cylinder at the banjo bolt/hose connection. I replaced my banjo bolts for nipple style.
Re: Clutch Issue
Yeah , the clutch can be a proper bitch to bleed . I do mine by forcing the fluid up from the bleed nipple on the slave cylinder , and bleeding air from the banjo bolt at the master cylinder ( as 900 streetfighter says ..... the bleed nipple there is a good idea too ) , some peeps even remove the master cyl from the handle bar so as to hold it at an advantageous angle ( hose still connected ) . My theory is that the internal diameter of the clutch hose is large enough to allow air bubbles to rise faster than you can "pump" them down ..... hence forcing fluid UP from the bottom works better . I used a large syringe. There is a tech tip in the FAQ's showing how to fit a slave piston assy off a later duke , which wont help you bleed it but it is a good mod to do when replacing the original piston/bearing assy900streetfighter wrote:Try bleeding from master cylinder at the banjo bolt/hose connection. I replaced my banjo bolts for nipple style.
- MarkST
Re: Clutch Issue
Well actually it will if you have it hanging loose and force the piston into the cylinder with a clamp, as then there's nothing in there to bleed out.Mc tool wrote:There is a tech tip in the FAQ's showing how to fit a slave piston assy off a later duke , which wont help you bleed it
2004 ST4S
2001 ST4
1987 Paso 750
2001 ST4
1987 Paso 750
Re: Clutch Issue
MarkST wrote:Well actually it will if you have it hanging loose and force the piston into the cylinder with a clamp, as then there's nothing in there to bleed out.Mc tool wrote:There is a tech tip in the FAQ's showing how to fit a slave piston assy off a later duke , which wont help you bleed it
