clutch problem
josephledezma
clutch problem
Post by josephledezma »
Just bought a 750 and awesome bike. Just put a new clutch on the manual only shows 6 fisk install. But at replacement comes with 15 .
Can someone help me find out how many disk total?
Re: clutch problem
read the F.A.Q
Re: clutch problem
Or the old school way is to take your bike apart, and take good notes on the order of the discs, and then compare the replacement pack you have to see which parts you will need, and which you will not. There may be only 6 of one kind of plate, but then 7 of the other, which would be 13. Later models used the same size plates, but added a plate for more horsepower, which would give you 15. Might it have been a kit that covers a wide range of years?
josephledezma
Re: clutch problem
Thank you.
