Running problem.
desmoluci
Running problem.
Post by desmoluci »
Ran the bike through the gears pretty hard today, and when I backed off it started running on one cylinder. When you open the throttle more, it starts running on two again with an occasional backfire through the exhaust. Changed plugs and no change. Anyone have any ideas what the problem may be?
Derek
Re: Running problem.
Post by Derek »
Blocked idle jet?
do check the voltage at the coils and CDI units and the wiring mod in the FAQs.
Brutus
Post by Brutus »
I was thinking of the coils also. Be sure to check corrosion on the pins where its connected to the wiring loom. Had a simular issue couple of years ago. Some sandpaper on the connection pins and it was running on both cylinders again.
Léon
desmoluci
Post by desmoluci »
Thank you, I'll start with the coils then to the carb. Sorry for the late reply, haven't been online for awhile.
I agree with the plugged jets theory.
Phil
ducinthebay wrote:I agree with the plugged jets theory.
Phil
Me too :)
