There is an issue with the gas tank - the front mount has a cracked weld, so under decel it can leak. It's not even enough to keep the tank clean, basically makes it wet and attracts dirt. A 20 year old "fix" (tank seler/epoxy) has let go and the leak is back. Also, one rear turn signal was broken in storage. I found some NOS replacements but they degraded enough in the box to not be useable, so the signals on it now are generic. I also have a Euro tail light for it with integrated signals but the lens on that is broken. Euro lenses are even harder to find than US signals it would seem...
$3400 cash. Not interested in trades. I am near Ann Arbor, Michigan. I will work with your shipper or can meet if reasonably close. PM me for more info or email desmodog (at) comcast (dot) net
