Mikuni conversion?
Posted: Sat Dec 30, 2017 5:52 pm
by commotoed
I have gotten my 750 sport out to finish my upgrades, anyone have any specifics on the oe mikuni conversion ( jetting, fuel pressure restriction...)
Re: Mikuni conversion?
Posted: Sat Dec 30, 2017 7:01 pm
by paso750
Have a look at the P750 FAQs.
Posted: Sat Feb 03, 2018 10:14 pm
by commotoed
does the mikuni conversion need the fuel pressure regulator?
Posted: Tue Feb 06, 2018 10:05 am
by paso750
If you had a P750 I'd say, absolutely but I don't know if the specs of the 750S in-tank fuel pump are the same as the one used on the Paso. I'd try w/o but do keep the return line to the tank. In case you run into problems try to remove the jet that sits in the Y-piece. This will increase the amount of fuel returning to the tank. If you still have problems you can add a fuel pressure regulator.
Posted: Thu Feb 08, 2018 4:09 am
by commotoed
Thanks, will do...
Posted: Thu Mar 15, 2018 3:09 am
by commotoed
https://www.youtube.com/watch?v=dliSUJACpw8
Awake after 8 years in storage, Mikuni conversion, Verlicci 2 into 1, rear shock rebuilt, forks serviced, new Michelins....
Posted: Mon Sep 03, 2018 3:44 pm
by 88Sport
Not bad from 8th Feb to Mar 15th
