Mikuni conversion?
- commotoed
Mikuni conversion?
I have gotten my 750 sport out to finish my upgrades, anyone have any specifics on the oe mikuni conversion ( jetting, fuel pressure restriction...)
90' 750 Sport
97 Gsf1200 aka Ziptie
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
Re: Mikuni conversion?
Have a look at the P750 FAQs.
- commotoed
does the mikuni conversion need the fuel pressure regulator?
90' 750 Sport
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
If you had a P750 I'd say, absolutely but I don't know if the specs of the 750S in-tank fuel pump are the same as the one used on the Paso. I'd try w/o but do keep the return line to the tank. In case you run into problems try to remove the jet that sits in the Y-piece. This will increase the amount of fuel returning to the tank. If you still have problems you can add a fuel pressure regulator.
- commotoed
Thanks, will do...
90' 750 Sport
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
- commotoed
https://www.youtube.com/watch?v=dliSUJACpw8
Awake after 8 years in storage, Mikuni conversion, Verlicci 2 into 1, rear shock rebuilt, forks serviced, new Michelins....
90' 750 Sport
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
78' 900 GTS (bevel)
98' Gsf1200 bagger
86' GSXR712
Not bad from 8th Feb to Mar 15th
