Thanks, Carl
Shock replacement
Shock replacement
Advanced this question awhile back and got no response. Maybe with the influx of new members i'll get the answer. Would like to upgrade rear shock to prefferably Ohlins. Can't find any listing for Paso series but seem to remember hearing or reading shock the same as 851/888. Can't seem to find listing for them, but know Ohlins made shock on 888 SP3 that i once had. Can anybody enlighten me?
Thanks, Carl
Thanks, Carl
Paul,
Thanks for the offer to check # but in my advanced years i'm unwilling to give up the convienience of a center stand. Believe with rising rate linkage, shock would be shorter than without. Also in most cases on Ohlins shocks, all you will be able to find is spring part number. Again, thanks for the offer.
Erskine,
Ducati part numbers mean even less to Ohlins people than to most Ducati dealers. OEM shock was decent for it's day, but until you replace with properly set up top quality Ohlins, Penske or other such aftermarket shock, you can't begin to appreciate how far modern technology has advanced ride and handling. To you also, thanks for your time researching this.
Carl
Erskine,
Carl
1564
rear shock
roll: got the duc bug, purchased 90 851 with 2k miles, as new org. condition to add to my 91 907ie...any way needed to replace stock rear shock on 851...unable to find ohlins or any other application other than penske...will be using this on 851....
I've been pursuing the shock question for over a year now. finally have settled on about the only available answer.
My preference was Ohlins, could find no listings anywhere. By the way, there is listing for 851/888, finally went to Ohlins USA. They said never produced shock for 907 and that the shocks they made for 750 were a contract order to Ducati, same as Gates produced cam belts to Ducati order these are unavailable for retail sale. Only thru Ducati. Ohlins USA said they would look thru perts bins for suitable pieces to custom build shock for me. No luck, Ohlins out.
Contacted Penske, they said had specs for 907 and could build their 8981 shock for this application. Ordered first of this week, will probably be three weeks til i recieve.
Will update as to if worth all the effort after installation and mountain trip.
Carl
Carl
1564
delivery time for penske shock
gldman36 how long from order date to delivery on shock...i ordered penske for 851 over 4 weeks ago and still have not received item....
