OK, having had to remove the tank and panels about a million times whilst sorting out carb issues, the missing tank bolt has bugged me. Does any one know the part number or if it’s used on other Ducati’s (would be weird if it wasn’t! ( I cannot see the bolt on the excellent stein dense website).
I enclose the one correct one I have.
Fuel tank fixing
Fuel tank fixing
- 2A0B0A8D-4087-4C4D-95F4-EFDCE818C2DF.jpeg (70.06 KiB) Viewed 54543 times
Re: Fuel tank fixing
There is probably a very similar bolt on a lot of bikes . Do you have a bike breaker/wrecker near by ,often you will get something workable for a couple of bucks
I've never seen that bolt. On my P750 it's as shown in the 750/906/907IE parts manuals. There's a black spacer in the rubber grommet and a hex bolt plus washer. One bolt that does it all is nice, tho
- Unbenannt-3.jpg (76.62 KiB) Viewed 54520 times
- DSC01904.JPG (160.13 KiB) Viewed 54520 times
- DSC01905.JPG (253.77 KiB) Viewed 54520 times
- Derek
- year: 1994
I didn't comment because I have a 907 but it has the same bolt fixing as shown in the Paso 750 as shown above.
Thanks every one for your responses. As wise people say, never assume. I just assumeD the one fancy factory looking bolt was standard! How wrong I was. I will knock up some sort of sleeve for a nice stainless bolt or s9mething,
Thanks again
Keith
Thanks again
Keith
