Ignition pickups ?
Stepaso
Ignition pickups ?
Post by Stepaso »
My 1988 White Limited Paso #754059 started running on one cylinder the other day, on the way back from a 40klm ride to get an ice cream through classic North Auckland back country twisty bush clad roads with no-one else on them ... every time I stopped the motor would cool down and it would go again on 2 cylinders.
limping home and after tracing no spark on the horizontal cylinder I found one of the pickups had gone open circuit, the other was 95ohm.
The bike is ex America so has Kokusan Densi ignition electrics, After lots of research I find I can get a new set for about $500 NZ$ but there is discussion on this board where people have used the pickup from a Fiat Uno, the only other info is they cost $19.
Can anyone offer any leads to reasonably priced parts or the part number of the Fiat Uno pickup ?
Ducati OE# 260.1.001.1A 26010011A
Regards Stephen
1988 Paso 750 White Ltd
1982 S2
angelix
Re: Ignition pickups ?
Post by angelix »
IGnitech in Czech republic sells an alternative replacement , however in NZ there is LIAM VENTER at Fast Bike GEAR (NZ!!) he has the replacement in stock for 49NZ$...
http://www.fastbikegear.co.nz/index.php ... ts_id=6792
he is also developer and importer for IGNITECH, he might be able to help you with a full set up with hall sensors instead of the traditional pickups. He has a kit for the 900 , but i think the same can or could be adapted to the 750, really worth giving him a call.
your pickups... would just be the pickups wiring going bad, it tends to crack so it could be something simple to fix, but I would go all the way and either replace them with new ones available through IGNITECH or FASTBIKE GEAR
For the more adventurous among us:
https://speeduino.com/home/
https://www.facebook.com/HandHeldDyno/ ---) these guys have interesting conversations but seem to be perpetually sold out or in production and almost all they do is much cheaper some where else
