eprom
Fvee3
eprom
Post by Fvee3 »
almost 2 months into owning this bike. I've done some mods that are described on this site and forth e most part the bike runs quite well. I still have air in the clutch issues' after riding for a while pressure builds in the line and the clutch starts to slip. Never had so much trouble bleeding a hydraulic system. new banjo bleeders for the slave and master on the way for that, but anyway back to the eprom post. I decided to see which chip was in the box since the airbox is open (sounds great by the way) and the exhaust (brand??) i don't know sound great also.
it has a stage 2 FBF chip F05005 which was installed 8/94 this is for high compression pistons. PO didn't mention that so is there a way to tell without pulling the head? i would think not but maybe there is?? Anyway just thought I'd put it out there and see.
Thanks for reading.
1992 Ducati 907ie Yellow
2018 Yamaha Eluder GT Silver
Re: eprom
I dunno about changing the chip to suit hi comp pistons ,I would have thought that if one was to arse about changing pistons surely you would go for the big bore kit.
I dont know much about 907's
Re: eprom
Google Borescopes and inspection cameras.
Original pistons are flat.
Fvee3
Re: eprom
Post by Fvee3 »
Great idea wish I’d have thought of that.
