Oil line...
Posted: Fri Feb 03, 2023 3:01 pm
by Sateme
Hi.
I have recently seen that this piece of the oil circuit does not fit in all Paso 750. In which versions were they mounted and what was their purpose?
Re: Oil line...
Posted: Fri Feb 03, 2023 4:45 pm
The answer is none. The same seller has a few other parts that are supposed to be Paso parts but aren't.
Re: Oil line...
Posted: Fri Feb 03, 2023 6:18 pm
by Sateme
But I have seen this engine with this part, like the one in the image.
It comes out of the lower radiator oil tube and goes to the rear of the crankcase.
Re: Oil line...
Posted: Fri Feb 03, 2023 7:00 pm
I stand corrected. Good eye! I've never ever seen or heard about that. By the looks of it the line is 20-30cm long. What is there to connect it to?! :huh:
Re: Oil line...
Posted: Fri Feb 03, 2023 7:30 pm
by Sateme
It goes to the rear crankcase bolt, where the anti-rebound brake bar bracket goes (look at the red line, that's the way). In this case it will be drilled.
