Winter Fettling
Thebenelliman
Winter Fettling
Post by Thebenelliman »
Been in the workshop working on my Benelli 900 Sei
just fitted an auxiliary fuseboard to save having loads of leads connected to the battery. This runs the headlight via a relay, heated grips, gloves and ignition supply via relay. The relays mean higher voltage to the headlight and ignition system the original systems run through the ignition switch and have at least a 1 volt drop over the relay system.
It’s now ready to balance the carbs before refitting the body work
The Benelliman
1992 907ie
1981 Benelli 900 Sei
1976 Benelli 125 Enduro
1981 Benelli 250 2c
1976 Benelli 250 Quattro
1980 Benelli 254
