I don't notice it in the handling but the guy at the testing station wants it all tight before he will give me a warrant of fitness.
I have taken the back wheel off and removed the linkage from the bottom of the shock and the rear part of the linkage from the swing-arm. There seemed to be no slack in any of these or in the main swingarm bearing. I can feel some play in the front bearing where the linkage connects to the steel frame of the bike.
My questions are:
Could this small amount of play be my problem or should there be some play there?
Can this bolt be removed without removing the rear cylinder header pipe? As the bolt has to come out in that direction.
The bearing of the linkage (arm) where it mounts to the frame has the following bearing:
HK 2030 INA VWX
I don't really want to go there If I can avoid it.
Cheers Marinus
