907 Plug & switch
Cybermunster
907 Plug & switch
Post by Cybermunster »
Looking for;
1- The plastic terminal/plug that connects the sidestand warning light, fuel gauge, neutral light wires to the bottom of instrument board.
I know, another probable "hopeless" search but trying anyway.
2- Rear brake switch as the current one I have to apply excesive pressure to activate.
Otherwise enjoying this fine machine....Thanks!! :thumbup:
wineliving
Post by wineliving »
One part was on Ebay but now it is gone. The rear brake switch you should be able to get from the dealer. I believe it is a Brembo part. On the rear switch make sure your brake fluid pressure/level is correct first prior to assuming it is the switch. Just some troubleshooting thoughts. I'll keep my eyes open.
Cybermunster
Thank Wine...that might just be it as the shop installed new braided brake lines recently, maybe it'll be a "need" for a bit of brake fluid.
Post by Tamburinifan »
Got my switch from a Ducdealer.
Cybermunster
Thanks for the info.
