Rear Brembo pump
Stefano
year: 0
Rear Brembo pump
Post by Stefano »
What is the name (code) of the rear brembo pump of Paso 750?
(PS 11 B)??????????? :confused:
DaveM
Post by DaveM »
this is from the part micro fiche : rear brake pump # 066441300.
hope it helps you.
Dave
Desmo_Demon
Brembo Rear Master Cylinder
Post by Desmo_Demon »
I contacted Brembo a little over a month ago about the model of master cylinder and a rebuild kit for it. This is the response that I got (these are Brembo part numbers).....
In regards to your inquiry, your bike should have the 20.2945.12 P108 caliper OE on the rear of the bike. The seal set you need is 120.2741.40.
You can purchase these from either of the following distributors:
TAW @ 303-456-5544
Yoyodyne @ 973-386-0040
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
Stefano
year: 0
Re: Brembo Rear Master Cylinder
Post by Stefano »
Desmo_Demon wrote:I contacted Brembo a little over a month ago about the model of master cylinder and a rebuild kit for it. This is the response that I got (these are Brembo part numbers).....
TAW @ 303-456-5544
Do you know the difference between the rear pump PS12 of Paso and the PS11B of 900ss from 91? :confused:
Desmo_Demon
Stefano wrote:Do you know the difference between the rear pump PS12 of Paso and the PS11B of 900ss from 91? :confused:
Sorry, but I do not know the difference. I bet the guys at Brembo can help. This is the guy who responded to my request for information on the Paso....
Jason Hilliker
Motorcycle Sales Supervisor
High Performance Division
BREMBO NORTH AMERICA INC.
1585 Sunflower Avenue, Costa Mesa, CA 92626-1532
T (714) 641-0104 ext.238 F (714) 641-5827
Toll Free (800) 325-3994
jhilliker@brembo.com
http://www.brembo.com
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
the PS11B piston is by 1mm smaller than the one of the PS12. next to this obvious difference the B models have the exit for the brake line not on the lower end of the housing, but it`s on the side.
Stefano
year: 0
Post by Stefano »
paso750 wrote:the PS11B piston is by 1mm smaller than the one of the PS12. next to this obvious difference the B models have the exit for the brake line not on the lower end of the housing, but it`s on the side.
Gerhard Mr. know it all :thumbup:
the internet knows things like these, I don`t :D
