Formal intro...
21783mike
Formal intro...
Post by 21783mike »
Hi all, My name is Mike and I am a Ducati addict :wacko: :banghead: I just acquired an 87 Paso, from a fellow in Dayton Ohio. It's going to need a little love as it had not been run much the past 2 years or so and the carbs are a bit gummed up causing a stumble at idle. I have some seafoam in it right now and it seems to be clearing it up and it's better each time I start it now. It's 2 tone yellow now as the paint that was used on the fairings is a bit lighter than the tank ect.... but she looks decent from 20 ft or so :lol:
Right now it has Mikuni's on it, I also got a set of Delorto's and the stock Weber. I also got another rear wheel, brand new front tire, a set of F1 pipes and a bunch of other misc brand new and used parts in a few boxes.
I put the F1's on this morning and that really made a difference, I believe the carbs are set up for these and the guy I bought the bike from had put the stock pipes back on for some reason...???????
Well that's it for now, I'm sure I'll have lots of ???? real soon though :mrgreen:
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
Finnpaso
year: 0
Re: Formal intro...
Post by Finnpaso »
Be sure, that Your carbs are adjusted to those F1 pipes! If it runs too "lean" (too much air in fuel mixture) with open pipes, then You can loose Your exhaust valves.... :smoke: Much more wiser to adjust only carbs, than loose some valves....... How about belts change? I mean, how old they are?
907IE -91 red/metal grey
907IE -91 red
persempre907
Re: Formal intro...
Post by persempre907 »
Finnpaso wrote:Be sure, that Your carbs are adjusted to those F1 pipes! If it runs too "lean" (too much air in fuel mixture) with open pipes, then You can loose Your exhaust valves.... :smoke: Much more wiser to adjust only carbs, than loose some valves....... How about belts change? I mean, how old they are?
If you don't know how old are the belts, change them at once!!!
Desmo_Demon
Re: Formal intro...
Post by Desmo_Demon »
Welcome to the club. I hope you get many miles of smiles from the bike!
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
Debonair
Re: Formal intro...
Post by Debonair »
Great! Another Paso member added to the site. WELCOME!!!!!!
21783mike
Re: Formal intro...
Post by 21783mike »
Thanks for the warm welcome folks...
I'm thinking I might put new belts on it eventually :roll:
The PO told me that he had just recently put the stock cans back on... so I know it had the F1's on it when he bought it.
I've seen pictures of other yellow paso's but there is no mention of "yellow" in the production #'s elsewhere on this site, I sorta like the yellow and am considering having the fairings repainted to match the tank ect... But I do think the whole bike would also look great painted the same pearl white that is on the 848's. Can someone point me to a good collection of photo's of Paso's so I might get some ideas?
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
Desmo_Demon
Re: Formal intro...
21783mike wrote:I've seen pictures of other yellow paso's but there is no mention of "yellow" in the production #'s elsewhere on this site, I sorta like the yellow and am considering having the fairings repainted to match the tank ect...
Yellow was never a factory color for the Paso bikes.
For pictures, I don't recall if we still have the photo gallery since the hacker attack, but you can go to Google or Yahoo and do image searches.
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
Rogero
Re: Formal intro...
Post by Rogero »
Our gallery is fully working and there are a couple of yellow and a few white ones's on the 750 pages.
Rogero
1992 "Red" 907 I.E.
Finnpaso
year: 0
Re: Formal intro...
Post by Finnpaso »
ALL yellows are repainted !!! :smoke:
907IE -91 red
Re: Formal intro...
if the red seat and the silver/red rims are original I`d say the original colour of the bike was white.
Maybe it was repainted as it fell over once, at least the brake lever is still bent.
21783mike
Re: Formal intro...
Post by 21783mike »
Yes it was dropped at some point, dunno how bad. The gauge cluster was replaced and the air scoops have been smoothed into the fairings with filler it appears, don't know it that was out of necessity or aesthetics. When I pull the fairings off over the weekend I'll know better once I see if any of the mounting tabs have been bent ect...
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
persempre907
Re: Formal intro...
21783mike wrote:Yes it was dropped at some point, dunno how bad. The gauge cluster was replaced and the air scoops have been smoothed into the fairings with filler it appears, don't know it that was out of necessity or aesthetics. When I pull the fairings off over the weekend I'll know better once I see if any of the mounting tabs have been bent ect...
I don't think she's had bad damages. The headlight seems centred in the front fairing.
When the Pasos have some bad accident, the headlight often goes back and out of the center because the frame's arms go bent.
Besides, see at the rear fork. If the bike was hard dropped, the fork is splined by the mufflers' nuts, because the rear footrests go also bent.
Re: Formal intro...
maybe it just fell to the right. The exhaust seems to show some scratches and the mirror seems to have the same colour tone as the tank. I wonder why the original brake and clutch pump were changed to the type with the round fluid reservoire.
If you remove the fairing check the 2 steering stops on the front of the frame. They are at the height of the lower triple clamp and prevent the steering halves to hit the tank at full turn to left or right. If the bike was crashed you can normally see that one stop (on the opposite side the bike fell on) is either bent or cracked. Some change the adjusting screw to a longer one if one of the stops is bent as otherwise it isn`t possible to set the steering so it doesn`t hit the tank. I know what I`m talking about I`ve had to do that after my first crash :?
Desmo_Demon
Re: Formal intro...
paso750 wrote:I wonder why the original brake and clutch pump were changed to the type with the round fluid reservoire.
Because they look cool. :smoke:
I changed the ones on my ST2 purely for the look of it. If I ever build up this MegaPaso, those are the master cylinders I'll put on it. I already have a spare clutch master cylinder. :wacko:
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
Finnpaso
year: 0
Re: Formal intro...
Post by Finnpaso »
For my eyes, those new style bottles, like i have in my ST2 and ST4s looks awfull compared to old style square model (like Pasos have), but its not only "looking", cause those newer systems are better ones in tecnical means.... Ducati changed to more newer style in Multistrada and 1098, etc bikes and those are best looking and surely also best quality products. As everybody knows, near allwas new products are better, than old products.... :smoke:
907IE -91 red
