My horn stopped working
Motorcyleboy
My horn stopped working, I checked the fuses and they are all okay. Any ideas?
- jcslocum
Re: My horn stopped working
About a thousand!
Do you have a test light or voltmeter?? This will help a lot with troubleshooting.
First thing tho is to check all of the connections that go to it. Grounds included that are bolted to the frame. Give it all wiggle and see if you can get it working.
- persempre907
Mine also. Simply, it broken.Motorcyleboy wrote:My horn stopped working, I checked the fuses and they are all okay. Any ideas?
Really, it's very easy find out if the horn doesn't work or if you have some electric issue.
You need to check if the current comes to the wires when you push its button.
If I managed to do it, you can do it by yourself, too
- Finnpaso
- year: 0
Very nice to see, that You, Frankie have learned to play with mutimeter...
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- Desmo_Demon
Yes, check to see that you are getting power to the horn. I there is power getting to the horn and it is not working, then the horn is broken. If you need another, I believe I have a spare Paso horn in my spares box.persempre907 wrote:You need to check if the current comes to the wires when you push its button.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
- Finnpaso
- year: 0
There is huge amount of car horns, what do same job. Only need to know power consumption/current of Paso horn.
907IE -91 red
907IE -91 red
- persempre907
Finnpaso wrote:Very nice to see, that You, Frankie have learned to play with mutimeter...![]()
Very hard work
- Finnpaso
- year: 0
907IE -91 red
907IE -91 red
