The late paso's have an improved engine, for example gearbox. Dunno exactly from which enginenumber, but it should be from approx number 4000 and up. Also these types were fitted with black passengerhandle, black yokes and gold valvecaps. If you're bike is one of this type it's surely worth its money.
regards, Léon
Potential PASO purchase
- Brutus
- year: 1989
Re: Potential PASO purchase
- streetsurfer
It appears the center stand is missing, or am I seeing things, or not seeing them for that matter?
We too, have a black cat. I also had a black one as a child. Sometimes I feel the first came back for another life and found me, as they both have/had a few white hairs on the chest.
I really like the color of the blue Paso's. Had I not bought the LTD, it would have been the Blue.
Best wishes in your dealing on this bike.
cw_v2
It is missing the center stand, good eye.
The black cat is definitely good luck.
- Finnpaso
- year: 0
Also some mods to camshaft system, as later have that easily removable clip to move rocker sideways, when need to adjust valve clearances...Brutus wrote:The late paso's have an improved engine, for example gearbox. Dunno exactly from which enginenumber, but it should be from approx number 4000 and up. Also these types were fitted with black passengerhandle, black yokes and gold valvecaps.
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- Brutus
- year: 1989
That's right..! Have had a paso with the number around 0250 or so, while my current paso has a enginenumber somewhere in the 4000 numbers. Adjusting the valves was indeed a bit more work then the one I have now..Finnpaso wrote:Also some mods to camshaft system, as later have that easily removable clip to move rocker sideways, when need to adjust valve clearances...Brutus wrote:The late paso's have an improved engine, for example gearbox. Dunno exactly from which enginenumber, but it should be from approx number 4000 and up. Also these types were fitted with black passengerhandle, black yokes and gold valvecaps.
- Finnpaso
- year: 0
907IE -91 red
907IE -91 red
