I`m looking for a friction bearing PAP2510 P10 (which I think is currently being discontinued and replaced by PAP2510 P14). Measurements are Od 28mm, Id 25mm, W 10mm.
Any idea where I can get one ?
I encountered 2 problems so far. My usual SKF bearing dealer doesn`t have them, but can order them with a MOQ of 5 (SKF doesn`t have that size and would need to make them on demand). Price would be €16 ea. and I only need one. I`d take two if they were cheaper (in an italian price list from INA they cost only €2,03+tax).
Secondly most online dealers have a minimal order amount and I only need this.
Any input is welcome. thx
friction bearing - where to buy ?!
- englishstiv
Re: friction bearing - where to buy ?!
any use?
http://www.bearingshopuk.co.uk/index.asp
or
http://www.apollobearings.co.uk/products.html
They do single item sales should be no problem to Europe and exchange rate pretty good too
or
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
- Desmo_Demon
Does SKF make one of these? What exactly do you call a friction bearing? Is it like a plain spherical bearing/"Babbitt" bearing (like those used on rod and crank journals of small block Chevy engines)?paso750 wrote:I`m looking for a friction bearing PAP2510 P10 (which I think is currently being discontinued and replaced by PAP2510 P14). Measurements are Od 28mm, Id 25mm, W 10mm.
www.skfusa.com
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
englishstiv, thanks a lot. I`ll try to contact them.
Terry, according to my online translator other expressions are bush/slide or sleeve bearing
Don`t know about Chevy engines, but the Duc Superlight uses one for its hanging rear caliper bracket.
http://medias.schaeffler.com/medias/en! ... /PAP..-P10
ok, found it. Just by chance I called a small store close to here and they can order them for 2 Euros something ea.
if anyone cares to know, the new P14 types are RoHS compliant (Restriction of Hazardous Substances, hence leadfree)
