Thanks, Vince
Paso valve adjustment
Are there any resources (other than the factory manual) that instruct how to set Paso 750 valves?
Thanks, Vince
Thanks, Vince
Re: Paso valve adjustment
Higgy,
Thank you!
Vince
Thank you!
Vince
- Finnpaso
- year: 0
One note: As stated in those articles, there are many ways to measure/adjust valves and i take allways belts away from my bike, as then its easy to rotate camshaft from upper pulley to find just right "area" to get feeler gauge in. I dont want to make any "war" about thiskind things and everybody can measure and adjust they valves how they want .... Then same time its easy to check belts condition much easier as they are out. I turn engine from left side by taking that small cover away(2 screws) and by putting simple "M8 screw tool" (M8 screw with one nut for locking this screw) to end of cranksaft and normal 13mm wrench to that "M8 screw tool" to turn engine to get marks to they right positions. Many ways to do valve job...
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- Maico88
If you are new to Ducati as I am, there is an excellent video about adjusting valves located here
http://www.youtube.com/watch?v=dIj3nSJGPZw
- Finnpaso
- year: 0
Very easy job, when sylinder heads are out from engine
907IE -91 red
907IE -91 red
- persempre907
Finnpaso wrote:Very easy job, when sylinder heads are out from engine![]()
But, that video is very well done!!!
