Case Saver info
- jcslocum
Case Saver info
I have been sent some info from LT Snyder regarding a new case saver that he is having made. This is a discotinued piece by ducati. For those that have seen a broken case from thier chain breaking you know what this can prevent.
A case saver is a small metal piece that bolts on in front of the front sprocket to protect the aluminum housing.
Case Saver Status: I just approved the prototype for the case savers. They are being manufactured next week and then get plated. I'm taking preorders beginning 20 April for them. The initial batch is merely to gauge interest. Tell your friends... Cost will be $22, which is below what Ducati was charging ($29) before they discontinued them. Theirs weren't plated either. :-)
For more info, contact: LT at LT@desmotimes.com
- fasterdammit
Jon - thanks for posting up about this. Sounds like a good idea to me - I'm interested, definitely. I just visited his site, but it turns out he's already hit his bandwidth allotment for the day (at 10:30am?!) So if you happen to converse via email or whatever, tell him he can count me in, too.
1988 Paso 750 #753965
1997 Monster 750
1997 Monster 750
- jcslocum
LT Snyder is accepting pre-orders for this very useful piece of
equipment:
http://tinyurl.com/eonmf
http://www.desmotimes.com
I am NOT selling this part nor do I have any arelationship with the seller. I'm just passing the info on.
Contact LT Snyder at the above web site to order.
equipment:
- fasterdammit
Re: Case Saver info
from the website
If there was something like that original from Ducati, anyone have a part number ?
it does not fit on the P750. Is there another ?NOTE2: If you have a variant with the clutch slave cylinder mounted to the right side of the motor, my case savers will NOT work.
- persempre907
Re: Case Saver info
I have them on both my 907s for long time.
That case saver was sold by Ducati as a racing accessory.
Somewhere, even if discontinued by Ducati, the number of the part would pop up.
I'll try to search it.
- Finnpaso
- year: 0
Re: Case Saver info
I am intrested of such! MAINLY from EU area, but if cant find from EU, then have to accept taxes from USA parts coming to EU.....
Btw, what is differend between 750 Paso and 907 case savers? Mr "G" ???
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- persempre907
Re: Case Saver info
Here's for you!
http://cgi.ebay.it/Ducati-Motor-Kettens ... 2eabd8b1a5
He states it will fit any Ducati... but I don't know.
Re: Case Saver info
Antti,
here`re pics of the case saver on a 750. As you see the lower mounting hole is where the bolt of the engine cover is and not where the the bolt of the sprocket cover is. Also the part is not deep enough to cover the engine case but only the cover.
I`ll make my own one.
- Finnpaso
- year: 0
Re: Case Saver info
Thanks, Gerhard
Seems, that next winter i will make some case savers for my bikes. I think, it needs some accurate measurements and suitable steel plate and it cant be "too difficult" job... Surely, if someone have measurements/drawing, then it is much easier...
907IE -91 red
907IE -91 red
