It looks like the Pasos didn't use the 40mm on-center mounting which became popular later; it appears my rear brake master cylinder has a 50mm on-center mounting. Can anyone confirm the pump size is 16mm (vs 11mm on the newer units)? I think I've found a replacement cylinder @ BevelHeaven http://shop.bevelheaven.com/detail.aspx?ID=1229. I think this the unit, going solely by mount description; I'll have to take a closer look at what's actually on the bike first ...
First call to business is replacing the cheaper parts & shortening the reservoir's lead, but I was curious if anyone knew of any rebuild kits for this M/C too?
