Don't know the exact date.
Mine yellow is '87 and it has not, while the red one I had has it, it was one of the last 750 built
fuel tank return ?
- ducapaso
Re: fuel tank return ?
ex...Red "smooth" 753349
maxpaso
fraser, how do you run your vent? do you have the twin vent/return lines or just one
ducapaso, mine is frame no751561 eng no 751253
will have a go at dismantling filler cap to see if i can drill a small hole through to vent it on the weekend
- davidbartoli
I Still have a Weber in my Paso, and No return Line on the fuel tank. Never had any problem in 70000 miles
The paso's with the return line were definatly faster
just stumbled over this in the user manual. Basically the same return loop as I had posted before.
