900SS brakes onto a 906
Hobbis
I bought a set of 900SS wheels for my 906 last night - want to go the 17" wheel route. The seller threw in the discs, callipers & brake lever for £30, so I'd like to use them too. Has anybody gone down this route already? The first obvious hurdle would be fabricating an adapter bracket to mount the 65mm hole centre calipers - does any one have dimensions? I misspent my youth as a draughtsman, so I'm pretty sure that I could draw up some manufacturing drawings.
if it has the 65mm brakes it should be > `97 as the models before had the 40mm (mounting hole distance) brake calipers
I changed to the 40mm calipers. You can find the info here. I don`t think the 65mm are suitable. They don`t position really good. I have some pictures as I had thought about using either these or the others.
http://www.geocities.com/750paso/
Gerhard
Gerhard
here`s the pic with the 65mm caliper
http://www.geocities.com/750paso/paso/4 ... sition.jpg
I have to correct myself. I kept the 16" wheels. If you change also to 17" wheels the 65mm brake will be o.k.. The technical drawings though might help although they are for the 40mm brake and the 280mm disc, regarding offset and fork mount.
Hobbis
Hi Pasochist, thanks for your reply. I think that the adapter drawings that you refer to provide a mount for a 40mm centre 4 pot caliper to a PASO 750/906 fork using a standard 16" wheel & disc. So the fork end of the adapter is usefull, but the caliper end not.
I think that starting from dimensioned drawings for the existing PASO brembo 2 pot and the 4 pot calliper that came from the 900ss (1999 year incidentally), then I could work up a bracket design.
So if any one can direct me to such drawings I'd be gratefull! I'm sure I've seen them on the Interweb soemwhere...
correct. In the link mentioned you also find the drawing of the 65mm brake.
http://www.geocities.com/750paso/paso/4 ... embop4.jpg
I guess with this, the basic info from the 40mm brake adapter, the knowledge of the Brake disc size it should be possible to draw the correct adapter.
Gerhard
Gerhard
Hobbis
Hello,
I have mounted 65mm Brembo calipers on my Paso 750.
See my post @:
http://ducatipaso.org/modules.php?name= ... light=65mm
//Anders
See my post @:
//Anders
Hobbis
