Pantah head on a Paso
Derek
Post by Derek »
A fella here in Scotland wants to know if he can fit a 500 or 650 Pantah head on to the rear cylinder of a 750 Paso motor. He is building a TT replica and has the Paso motor. He is aware that the valves are smaller but that can be fixed.
ducbertus
Re: Pantah head on a Paso
Post by ducbertus »
Hi Derek,
I think this is possible as the base of these engines is the same.
when you swap those heads, partucular the vertical one the Pantah camshaft has to be used as the inlet valve moves from the front side to the rear side of the cylinder. the 750 engine has a few mm. larger bore and a longer stroke.
Bertus
ducinthebay
Post by ducinthebay »
It has been done before.
Here is the one that RAD Ducati did:
http://radducati.blogspot.com.es/2012/0 ... -2012.html
And I believe Loud Bikes also did this after he blew up his F1 motor.
I'm sure it isn't just a straight swap, but there are a few people who have done that can help him through it.
Phil
As far as I remember a 500 and 600 cylinder has a different cylinder stud distance. Don`t know about the 650.
Derek
Post by Derek »
Thanks guys I will pass on this info. I'd already mentioned the camshafts but didn't know about the possible stud spacing change.
