If you are after a set of Barrels, Pistons and Rings for a 906/907, have a look at:
http://www.ebay.com.au/itm/Ducati-851-9 ... 2a3096b342
Check the postage with Jim or Ian first though! It looks a bit odd...
Cheers.
Nick.
Barrels, Pistons and Rings from Italspares
- Derek
- year: 1994
Re: Barrels, Pistons and Rings from Italspares
I'd be a bit concerned about these pistons though. I've never seen a 4 valve 906/907 beforenickta wrote:If you are after a set of Barrels, Pistons and Rings for a 906/907, have a look at:
Cheers.
Nick.
nickta
[/quote] I'd be a bit concerned about these pistons though. I've never seen a 4 valve 906/907 before
[/quote]
Hi Derek.
Had a closer look at the picture in the eBay ad. Yeah, I can see what you mean. I purchased a set last month, thought I had better take a closer look. The set I got have the gaps for a 2 valve head in the pistons. I guess its a generic picture?
A 4 valve 907, hmmm...
Cheers.
Nick.
Hi Derek.
Cheers.
Nick.
- ir_joep
- year: 1989
hi
i think its a 851/888 big bore kit hence 907 cc
they have 4 valves and no fcolling fins
cheers Joep
cheers Joep
