lockable gas cap in the Netherlands
http://www.marktplaats.nl/a/motoren/ond ... ousPage=lr
it does not fit on the 907ie as the hole diameter is different.
persempre907
Re: lockable gas cap in the Netherlands
Post by persempre907 »
paso750 wrote:it does not fit on the 907ie as the hole diameter is different.
Are you sure G.?
I have got the same one on my red 907.
Really, my black 907 has a different cap (same key of the ignition switch).
really, there are two different ones on the 907ie ?
750/906
outer diameter flange 120 mm
hole circle flange 102 mm
gascap 76mm
907ie
hole circle flange 110 mm
gascap ?mm
persempre907
paso750 wrote:really, there are two different ones on the 907ie ?
750/906
gascap 76mm
907ie
gascap ?mm
It's so. My earlier 907 has the same cap of the 750/906.
The later '92's 907 has a larger cap.
