Does anyone have any recommendations for a new exhaust system, preferably available in the UK?
Roderick
750 Replacement exhaust???
Re: 750 Replacement exhaust???
conti's mate i have these when not being m.o.td desmodave squires cafe we are on the net.roderickw wrote:Does anyone have any recommendations for a new exhaust system, preferably available in the UK?
Roderick
Roderick,
I was doing some research into this myself. I sent an e-mail to Italy a few days ago but have not recieved a reply yet on this set:
http://www.termignoni.it/catalogo/sched ... 20STR%2040
Possibly the fact that you are a little closer to Italy and Termignoni they may give you an answer sooner? I am thinking that these will work if you make your own mount brackets (items 3 and 4 in the picture).
It is listed for a 750SS from 1989. These bikes both used the same motor (Pantah 750) what I was trying to determine is the exhaust size in mm. This should be a 36mm correct for Paso 750. If it is available and it will work please let me know. The next possibility is a Conti system
http://www.dropbears.com/o/overlander/d ... hausts.htm
Again you will need to order from Australia.
These are the only ones I've found so far unless you are lucky enough to have the 40mm exhaust (rare on the 750) then you can use the 907ie exhaust system from Two Brothers #005-160406D.
http://www.twobros.com/cgi-bin/shopper? ... 907ie.html
All are expensive!
I hope this helped some and if you get any information please pass it to me.
Doug
All are expensive!
Doug
Found a replacement system!!
Thanks for all the replies. The DOCGB magazine issue 122 mentioned a guy in Staffordshire who did a system for Paso's. A quick buzz up the M5 concluded with the parting of £300+ for a shiny SS system which is reminiscent of cut down Conti's. It looks great and sounds really good.
URL < http://www.OSMC.co.uk >
Check it out.
Best
Roderick![:cool: :cool:](./images/smilies/cool.gif)
Check it out.
Best
Roderick
- Harigeharry
They come along around €150 but sometimes taxes are added.paso750 wrote:I guess there is none if you can`t find any Cobra F1s somewhere.
Some dealer may hove some NOS parts though.
I bought Leannart und Wagner pipes for €90 in Germany.
They fit perfectly and sound great (very loud though).
Bauke had them on his Paso. Somewhere on this site.
Bauke 1
or
Bauke 2
- Finnpaso
Harry, do You know that shop, what sells those pipes to that price??? Or was Yours used ones (from Ebay maybe??)
- Harigeharry
