Hi,
I`m having difficulties finding a clutch kit for Ducati 750 / 906 Paso - they become scarce around these parts...
Questions are:
will the 907 kit fit?
Can Anyone recommend on a good web shop that carry Paso parts?
Thanks,
Eli Attias
Clutch kit
- Finnpaso
I am quite sure, that 907 kit fits to 906, but have those early 906s(slave sylinder in right, like in 750 Paso) samekind disc kit, as later 906s with slave sylinder in left???
f1steveuk
EBC in the UK (although they sell worldwide) list kits for the 750, 906 and 907ie, and I am sure there's a full comp kit listed on http://www.demontweeks.co.uk
eliatt
Thanks all,
As I recall, difference between all dry right sided actuator models is only the use of thick one- sided friction plate, close to the "c" clip spring. this set up is used on Paso 750, 1989 Paso 906 , 1988-1990 750 sport, and early model 750 ss. the 907, I dont know about: never imported to Israel...
However, if there is a way to do without that one - sided plate on top, I`ll be more than happy to learn more about it. maybe replace it with a double sided one?
Thanks again!
Eli
Thanks again!
Eli
