Gear indicator and led revcounter
ducapiero
year: 1985
Post by ducapiero »
Hy guys as i said in another discussion i mounted in this past week end this two very necessary objects :D :D :D
now the gear indicator function normally but there are problem with the rev counter....
after connecting the red-positive and black to ground,there are two wires coming out from the tacho orange and brown....i don't know what of these take impulse from the engine and i make tests but when i connect orange wire to pick up positive cable it lights on all led in sequence but this led don't follows motors rpm :oops: :oops: :oops: when i connect brown wire to cable sometimes all the led lights together :shock: :shock: :shock: :shock:
do you have any ideas???al suggestion are accepted
many thanks
lamps
Piero
Re: Gear indicator and led revcounter
as both are aftermarket parts do you have an electrical/installation scheme of both parts to look at or did they come without any documentation ?
If so knowing model and brand may help.
G:
ducapiero
year: 1985
Post by ducapiero »
i read very very little wroted on the circuit datatool and that's the brand!!!! :) :) :)
i found the site and the manual all is ok today i finsh to mount and i give you news :mrgreen: :mrgreen:
pls. make pictures of the mechanism of the gear level indicator. I`d like to know how you solved that with the microswitch and so.
G:
Here gear indicator (red LED seven segment)coast "about" 86€ and its connected to both speed and rpm circuits, nothing mechanical. 8)
interesting ! I never saw this type, only know the old one that required microswitches at the gear lever.
who`s interested ... ie.
http://www.biketronix.info/Shop_NL/index1.html
http://www.riderstation.com/DG8_Instr_Feb_03.pdf
(regarding connections these two seem to be already quite different. If you look at the first link and then "Handleidingen", then whatever model one can see that it uses a wheel sensor, the other one doesn´t)
G:
ducapiero
year: 1985
Post by ducapiero »
I have a new digital dashboard and the gear indicator needs digital speedo,there is also a tipe for anlogic speedo but is much expensive... :evil: :evil:
i'll post photo when i reassemble bikelamps
Piero
mike
Post by mike »
I am almost 100% convinced I will be installing one of these on my cafe bike to reduce the amount of clutter above the triple tree.
http://www.trailtech.net/computers.html
I'm thinking about the Vapor plus the dashboard with indicator lights so that my charging circuit functions as it should. Just like this:
The whole thing can be done for about $150 :!:
Cheap FOR YOU! :) But i think, not so cheap to us EU guys... If someone know seller here in EU, then it "can be" also cheap for us... :twisted: Anyway, it looks quite good! 8)
Post by jcslocum »
Finnpaso wrote:Cheap FOR YOU! :) But i think, not so cheap to us EU guys... If someone know seller here in EU, then it "can be" also cheap for us... :twisted: Anyway, it looks quite good! 8)
With the Dollar sinking like the Titanic, this will set you back about 5 Euro...... If you want one, have it sent here and I'll ship it to you!
:mrgreen: Thanks, Jon! :D Soon i have DD headlight kit and new nice dashboard to my Ducatis... :lol: (joking little)
I was once thinking about the Aprilia RSV Mille instruments as the shape of the whole panel is somewhat like the one of the Paso, but I like it as it is (specially the fuel indicator). Plus I think it`s quite hard to adapt unless you`re using 17" wheels etc.
mike
Post by mike »
paso750 wrote:I was once thinking about the Aprilia RSV Mille instruments as the shape of the whole panel is somewhat like the one of the Paso, but I like it as it is (specially the fuel indicator). Plus I think it`s quite hard to adapt unless you`re using 17" wheels etc.
not to mention the fact that anything that wears the name APRILIA will be quite expensive
Everything is relative so, here in Italy, the Aprilia stuff is much cheaper than the Ducati stuff.
mike
Post by mike »
persempre907 wrote:Everything is relative so, here in Italy, the Aprilia stuff is much cheaper than the Ducati stuff.
Indeed this is true :)
