Clutch help needed
eliatt
Clutch help needed
Post by eliatt »
Hi all,
Can anyone supply me with the measuraments of the mushroom-like part located on the clutch slave cylider? the stem goes in the bearing, and is 8 mm. diameter, the rest - I don`t kow of. I guess that the "mushroom" head should be approx 15 mm. diameter, since it`s in contact with the pressure plate that has approx. same contact area.
I`ll appreciate your help!
Thanks in advance,
Eli
Re: Clutch help needed
http://forums.ducatipaso.org/viewtopic. ... ilit=brass
btw. the pin dimenstions are:
___________________
I.............................I
.........I.......I
.........I.......I
..........\___/
diameter top: 16mm (0,63 inch)
total height: 9,10mm (0,358 inch)
height of flat top: 2,20mm (0,086 inch)
diameter of the lower section: 7,97mm (0,314 inch)
eliatt
Post by eliatt »
Hi,
Thank you very much!
Eli
ducapaso
Post by ducapaso »
there're various kind of those pins: they can be steel or brass, the top diameter can be 16mm or smaller, in the lower part of the top there might be a sort of step to leave a clearance with the rubber gasket of the bearing and let the pin touch only the inner ring of the bearing... Italian handcrafters aren't so hardly connected to the standard models! ;)
