hi would this fit my 88 750 sport / paso?
http://motographix.co.uk/html/other_stuff.html
cheers.
clutch slave seal fitment ?
Re: clutch slave seal fitment ?
As the Paso and Sport have an O-ring it could be that the piston has a round shaped groove. (don`t remember)
I`m using a clutch piston of a 900SS/749/996B/900M and this one has a V-type seal and a square groove.
Better check if you remove your piston. I don`t think it`s ideal to put a seal that`s made for a square groove in a round shaped groove, if that is the case.
However, it was done before. Check the FAQs.
G
G
looks good. If the outer diameter is 26mm the Xring of these models should fit
cat980
just an update from that link in my original post.it fits my piston and works a treat on my 750 sport...phew.
http://cgi.ebay.co.uk/Ducati-Clutch-Sla ... m153.l1262
