BUB Exhaust ????
- ducinthebay
BUB Exhaust ????
I have a set of BUB exhaust pipes for my 750 Sport project. I am trying to take out the baffles to repack them. Has anyone else ever taken these apart? There is a rivet in the back that I drilled out, but getting the core out is proving difficult. I have tried several bearing pullers, but I just can't get enough purchase on the inside of the core to get it loose.
Any insight is appreciated.
Re: BUB Exhaust ????
Most after market exhaust will have a length of the baffle that fits tightly at the front. A little heat from either propane or mapp without oxy will usually be enough to allow the baffle to slip out.
Also most of the baffles I have run across have more than one rivet. Others the can comes off and the baffle is part of the header system. I have never taken a bub system apart so your mileage may vary
Never seen a Bub system so pics would be nice!
- ducinthebay
Yup, mine look just like that, scratches and all, except mine are flat black. They have a reverse cone on the end that they welded to a baffle core. The whole bit is (as best I can tell) slipped into the end of the pipe and one pop rivet holds it in. I tried the heat already. Maybe I'll try more. Surely can't ruin the finish of flat black rattle can. I sprayed on some penetrating oil, so maybe that will work its magic in a few days. I also rapped on it with a hammer all the way around to loosten things up. I'm using an expanding core bearing puller with a slide hammer, but the core just doesn't get enough purchase and keeps slipping out. I need to make a better puller bit I think.
Currently, BUB makes pipes mostly for Harleys and other cruisers. A California company that sponsored the land speed record bike the past few years. They made pipes for the Paso, and apparently the Sport. The Sport pipes are just a bit shorter than the Paso pipes, as the Paso headers are shorter than the Sports.
- Fraser
- year: 1986
Ducinthebay,
Have not been inside a Bub muffler, but they are all different and never as you imagine. Here are some photos of inside a Suzuki GX1400 muffler that I stripped out for a wee project that I'm working on.
The end cap looked like it was held on by 6 rivets, this was just to fool you. Tried opening it up with a plazma cutter, that didn't work, so cut the last 100mm off the end with a tungstin blade in a drop saw.
Inside was a huge baffle, a thick lining and the whole thing was very heavy.
Once all the crap was removed it worked a treat, light and sufficiently noisey.
Fraser.
Fraser.
750 Paso
1980 Moto Morini 500 Sport
- englishstiv
I know when I cut down my Monster exhaust the front of the baffle had been tack welded in situ and no amount of heat woulld seperate it in the end I ground it through and then re welded I wonder if yours may of had a similiar build set up if all else fails run a grinder around the front seam and see it that loosens it, if it is in matt black already you can re weld and re paint good as new.
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
pls. don`t post pics bigger than 1024x768. thx.
- englishstiv
soz don't know why it has done that? It's from my usual photobucket site, have deleted it now.
DUCATI 907ie 1992
you didn´t have to delete it immedeately
I was just saying that for the future and for everyone. I guess standard monitor size is still 17" and 19" although they`re getting bigger and bigger lately. 1024x786 is still a good picture size for this forum and such a screensize w/o having to scroll up and down or side to side to see the whole picture.
I have had issues with photobucket as well from time to time with photo sizing...fyi
