tach cable????
Vince
tach cable????
Post by Vince »
Hey, do you guys know where I can get a tach cable at :banghead:
Foxtee
Re: tach cable????
Post by Foxtee »
1990 750 Paso
2011 Suzuki Bandit 1250 S
Vince
Re: tach cable????
Post by Vince »
yea but will those fit
Foxtee
Re: tach cable????
Post by Foxtee »
Check the maker name on the gauges eg. Veglia or Smiths ,
mine show Veglia on the speedo only, but the thread on both is the same. The speedo cable I got last year fit perfectly.
You could also drop them a email , I've found very helpful.
:D
1990 750 Paso
Re: tach cable????
beware that different Ducs use the same cable but in a different length.
I had bought one some time ago which should have been for the Paso. I noticed it did pull a little on the rubber guide ring on the fender. I ignored that and kept working on the bike turning the steering once in a while until I noticed the instrument cluster was moving although the rubber dampers were all new. When full steering the cable was pulling on the panel which is why the rubber dampers came apart. The one I have now is a bit longer. Total length is about 900mm.
Maico88
Re: tach cable????
Post by Maico88 »
Don't know about now, but about a year ago I got a tach cable for my 750 Sport from the local Ducati dealer. My Sport has Veglia gauges.
