Hi, What voltage should i be getting from the stator to the regulator/rectifier?
I'm getting about 20V from the stator, i wasn't getting any voltage after the reg/rec. so i fitted a new one but still have no voltage from it.
Cheers, Gary.
Charging fault
Re: Charging fault
20 v is way lean should be an output of 120+ measured at the stator
Re: Charging fault
Cheers for that, i'll get looking ![:) :)](./images/smilies/smiley.gif)
