Hi Guys again!!!
I want to upgrade the black rear brembo caliper on my sport to a gold Brembo...
The problem I see is the bolt gap... mine is about 88mm centre to centre.... the the gold Brembo stuff is 84mm
Can anyone advise on what I can do?
750 Sport Rear caliper
Re: 750 Sport Rear caliper
Tony, the caliper mounting bracket of the golden caliper is for a smaller diameter brake disc and that brake disc can`t be fitted on the 16" rim. The only things you can do is paint the old caliper golden, make a new mounting bracket to fit the newer golden caliper with the Sports rear disc (or do the complete 17" conversion)
Thanks for your help..
T
T
