Spark plug recommendations for 750 Paso
Kurt woolley
Post by Kurt woolley »
Can anyone give some help in choosing the right spark plugs for my 750Paso. Thank you.
Re: Spark plug recommendations for 750 Paso
Champion RA6HC
Kurt woolley
Thanks, I know that is what the owners manual says, But I have never had good luck with Champion
Plugs. Have they worked well for you? Is there another better plug? I see the Bosch silver sport #7701 or
Xr4cs listed. Would that be a better choice? Thanks for your help.
+1 Champion RA6HC
Derek
Post by Derek »
I've always has good results with NGK plugs. The DCPR8E is recommended for the 750 Paso.
Brutus
Post by Brutus »
Derek wrote:I've always has good results with NGK plugs. The DCPR8E is recommended for the 750 Paso.
+1 :cool:
Iridium plugs is also an option: DCR8EIX. Gap should be 0,8mm. Esp on the "low" compression pistons ;)
while you can go with iridium, platinum whatever plugs you`ll notice that the most simple ones work best.
Kurt woolley
Thanks for the help, one & all!
The champions run best in the Sport for me. And they are cheap. Less than $2 at the local auto parts store. I never had a good view of Champion plugs in the past, but they work better than any $10 plug I've tried.
Kurt woolley
Thanks again!
Kurt woolley
Just bought them at Autozone for $1.95 each! I hope they work...
if you would do a little searching here on plugs you would find a lot of Paso owners before they had a Paso wouldn't put champions in there worst enemies lawn mower.Then they bought a Paso,or 2 or 3 and we all use Champions now
NGK iridiums work but the simple fact is champions will last longer and for a lot cheaper
Kurt woolley
Thanks for all the info! Such a Cheap little plug on such a Great motorcycle. I am glad that they work!
