where to get brass freeze plugs
I need help finding freeze plugs to complete the engine rebuild and have had no luck with searches. it looks like I need 16mm and 18mm brass but cant seem to find a place to buy them. any help would be greatly appreciated.
Re: where to get brass freeze plugs
from another Duc forum:
"87310201A 20mm
87310051A 18mm
87310011A 16mm
87310021A 10mm
If you type in Ducati then the part number (without the 20/18/16/10 etc) you should find a few that sell them."
I assume shops that build engines or shops for agricultural machines should have these, too.
This is a great site for parts cross reference: http://www.desmoduck.com/index.php. Just copy and paste the part numbers into the last field and you get an overview in which newer models these parts were also used.
"87310201A 20mm
87310051A 18mm
87310011A 16mm
87310021A 10mm
