Headlight conversion
@ all
does anyone know a headlight conversion where you can get some decent light out of your Paso?
If I drive in the dark my headlight does not give enough light in comparison with my friends japanese bike.
greetings
greetings
- Finnpaso
- year: 0
Some (like i) have made 2 round headlight modification to Paso. That is better in 750 Paso, cause 907 dont have enough big charching system for keeping ALL time two 55W bulbs on. Injection takes too much current from battery...
There are many ways to do such modification, so all depends, whatkind lights You managed to find. Surely some job, but can be done.... :laugh:
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
0,5V is not much but according to some graphics I`ve seen 4-5% less voltage can mean up to 10% less brightness. Not sure how good the eye is to distinguish this as this is purely theoretical.
However, I`d try to directly connect the front light to the battery just for testing (!) if you can note any difference with or without full voltage (when engine is running). Then you can still see if it`s necessary to swap the front beam or not.
- Finnpaso
- year: 0
I have some, but NOT in internet available, only in CD, so if U want some, You have to send Your @address (what have space for fotos!!!) to me to: finnpaso@gmail.comlammy1 wrote:@ finnpaso
do you have pictures off your modification?
I am thinking about such a conversion.
It can take some days, when i have time at work, but function that way...
907IE -91 red
907IE -91 red
here`re all pics of dual headlight conversions I have:
http://www.pbase.com/paso780/inbox
(I don`t like any of them)
- persempre907
I agree, i don't like too much the modifications but this is intriguing me...
http://www.pbase.com/paso780/image/70970835
- persempre907
- persempre907
It's a little pity, even if I don't like too much the modification.paso750 wrote:yep, found that on a danish page and it said something about photoshop below it.
Then the ST3 has a pointed nose so the light would not fit on the flat Paso nose.
But, this would be a good modification.
- zap
yo lammy1,
you could try to get a yama.. fz 750 headlight (double bulb) from the 80's versions, but it can give you a problem with the rest of the electrical system (too much power)
i use only one bulb, a philips halogen gold 55w, i'm satisfied with it.
sorry guys, dutch now.
je kunt ook even kijken op ebay, doe ik ook vaak.
je kunt er veel paso onderdelen goedkoop kopen en de yamaha koplamp is er ook regelmatig te koop.
xenonlampjes zijn ook nog een optie, al houd ikzelf niet van dat wit blauwe licht.
succes
ab.
succes
- wilbur
Yikes!
Dual headlight makes the paso look like a bug! :thumbdown:
I was thinking about doing the dual headlight conversion but I don't think so now.
The photoshop picture looks interesting though. hmmm.
Tim
Port Murray, NJ
1987 Ducati 750 Paso
1995 Ducati 900SS SP
1999 Ducati 996
1998 ST2
2000 Honda RC51
Tim
Port Murray, NJ
1999 Ducati 996
1998 ST2
2000 Honda RC51
