Parts Interchange
Parts Interchange
Hi all,
I was wondering if anyone has any suggestions for a side stand for my 907ie. The Dealer is telling me that it has a different part number than the side stand for a 906, 851, and 888. There is a side stand from a 1990 750 paso on E-bay right now, but the dealer doesn't even show a 1990 750 paso at all. All he has is 750 Super Sport, and it's a completely different part number. So my question is, are there any models of ducati that have the same length and mounting for the side stand as my 907ie?
Thanks,
David
Thanks,
David
- persempre907
The 750's side stand number is 037012500.
I'm not sure the 750's side stand fit also on the 907.
The 907 is higher than the 750 because of the 17" rims.
So, the side stand also could be higher.
- Finnpaso
- year: 0
...seems to my eys, that they are same and caused by 17" wheels, 907IE stands little "too down" compared to 750 Paso, what is more "upwards".
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- persempre907
The numbers are different, but, since you have both the bikes you could tell us the decisive word, above all if you measure themFinnpaso wrote:...seems to my eys, that they are same and caused by 17" wheels, 907IE stands little "too down" compared to 750 Paso, what is more "upwards".
- Finnpaso
- year: 0
My 750 sidestand is modified for Conti mufflers, so i dont know, are they same. I can look from microfilm, but they can be same, no matter, if different numbers... many times i function that way with Ducati factory.... :screwy:
907IE -91 red
907IE -91 red
- wilbur
Another kick stand on Ebay if you still need one.
http://cgi.ebay.com/ebaymotors/DUCATI-7 ... 0050QQrdZ1
Tim
Port Murray, NJ
1987 Ducati 750 Paso
1995 Ducati 900SS SP
1999 Ducati 996
1998 ST2
2000 Honda RC51
Tim
Port Murray, NJ
1999 Ducati 996
1998 ST2
2000 Honda RC51
- persempre907
I'd buy it.
No matter, the frames are the same, except for the front side (radiator and headlamp subframe) so you can fit it for sure.
- Finnpaso
- year: 0
Btw, those side stands are made from alumium, so if U know some aluminium welder, he can "reweld" it to suitable, like i did to mine for Conti pipes. It brake easily, if U try to bent it by own tools. ST series have steel side stand.
907IE -91 red
907IE -91 red
- persempre907
I hope you are fine
Has the swingarm only dents or is it bent?
If there are only dents you can fill up with the aluminium.
You have also to do a metal casting and then you will take off the excess and will brush it.
It will look as new
