Hello paso freaks and owners,
Does anyone know what type of pickups the Paso have, Hall, magnetic or something else?
BR
//Anders
The pickups - Hall/magnetic or what
- Finnpaso
- year: 0
.... and those pick ups MUST be very well adjusted....
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- ducinthebay
pickups
There are two different types on the Paso's and Sports.
Two pickups in the case, and a single pickup version that mounts from the outside of the case at the 2 o'clock position with two little screws. The latter was common in the California bikes, as there is no way to adjust the timing. As mentioned, the gap is critical. The single pickup type is set with little shims. The ST2 motor is similar in regard.
The single pickup version used the Magnet Marelli 2s computer, which is a finned aluminum box under the seat with a big wire connector and a vacuum hose attached. About the same size as your voltage R/R.
