The pickups - Hall/magnetic or what
ansim
Post by ansim »
Hello paso freaks and owners,
Does anyone know what type of pickups the Paso have, Hall, magnetic or something else?
BR
//Anders
ducapaso
Post by ducapaso »
They're magnetic, and they're placed inside the left cover of the engine. Be careful in removing that cover, as it requires a special tool as extractor.
Finnpaso
year: 0
Post by Finnpaso »
.... and those pick ups MUST be very well adjusted.... :evil:
907IE -91 red/metal grey
907IE -91 red
ducinthebay
pickups
Post by ducinthebay »
There are two different types on the Paso's and Sports.
Two pickups in the case, and a single pickup version that mounts from the outside of the case at the 2 o'clock position with two little screws. The latter was common in the California bikes, as there is no way to adjust the timing. As mentioned, the gap is critical. The single pickup type is set with little shims. The ST2 motor is similar in regard.
The single pickup version used the Magnet Marelli 2s computer, which is a finned aluminum box under the seat with a big wire connector and a vacuum hose attached. About the same size as your voltage R/R.
