Hello,
i have a starter problem with my 906. when i push the start button
i hear the starter relais work, but the starter motor doesn`t turn.
The battery is OK. Can someone give an advice?
Greetings from Germany
Timmy
Starter problems
f1steveuk
Re: Starter problems
Hi Timmy, snap, same has happened to me, exctly the same!Timmy wrote:Hello,
Timmy
http://forums.ducatipaso.org/viewtopic. ... pic&t=1286
I brought a new starter fom ebay, but as yet haven't fitted it, altough I think I may try and rebuild it in situ, as I really don't want to take the engine casing off. Hope someone helps you, because it will help me too!
