907IE Ignitors - Ignition module BKL-3B
Post by Tamburinifan »
So I switched tonight, problem remained front cyl.
Measured contact to injectors, 12.5V on both. Lubed signal/+V to injectors - no result.
So I guess front injector is stuck/ semiworking.
Report will follow, at least I have 4 green ones to test with. :thumbup:
Finnpaso
year: 0
Post by Finnpaso »
Have You changed wires from coils to spark plugs? One of such have failed in my 907 and again find right size/modell quite chealpy from car spare parts shop. :evil:
907IE -91 red/metal grey
907IE -91 red
Have You changed wires from coils to spark plugs.
No, but switched (as said before) ign signal input + wire between coils, problem remained at same cylinder = no problems w coils-wires-cap.
Right?
Finnpaso
year: 0
Post by Finnpaso »
Have U cheked sparks in plugs??? Sorry, but i havent read hole topic from start... Engine needs spark in plugs and fuel to start. If other is missing: No start! :evil:
907IE -91 red
