1992 907ie with no service records
macwig
Post by macwig »
I recently bought a 92 907ie from a car dealer and they had no service records at all.Is there any online database to find out where and when service was done on this bike??
no, unluckily there isn`t, specially as noone knows if the bike was serviced by an official Duc dealer or some other shop.
Best will be to find out the last owner and ask him otherwise start from zero, change all fluids, plugs, filters and the belts and check valve clearance.
Desmo_Demon
Post by Desmo_Demon »
paso750 wrote:otherwise start from zero, change all fluids, plugs, filters and the belts and check valve clearance.
I would probably do all these things regardless what any previous owner tells me. It's better to be "safe" than to be broken down on the side of the road with a disabled Paso. :sad:
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
persempre907
Post by persempre907 »
Above all the timing belts.
They have to be changed every 20.000 km (16.000 miles).
If they go broken :ugh: :sad: :ugh: :sad: :ugh: :sad: .
macwig
service records
Post by macwig »
Thank you all and in the spring I will do full service as recommended.Mac
1992 907IE
1983 BMW R100
Desmo_Demon
persempre907 wrote:Above all the timing belts.
I think it is 12k miles...or two years...whichever comes first.
(I typically go for 12k miles or up to four years, though)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
Rogero
Post by Rogero »
BIG service every two years will keep things fine as long as you are not doing very high mileages.
Look after the battery though...
Rogero
1992 "Red" 907 I.E.
Ducman
Re: 1992 907ie with no service records
Post by Ducman »
LOCAL MECH ADVICE...FOUR YEARS MAX ON BELTS
