750 Paso front brake adapters to swap 320 rotors to M1R
Finnpaso
year: 0
Post by Finnpaso »
Have anybody done such adapters to 750 M1R fork with 4 piston "black" Brembos, or "gold line" 4 piston Brembos???
Now i have normal cast iron original 280mm rotors with adapters to 4 piston black Brembos, but planning in future 17" conversion with same calipers to original M1R fork, but with 17" wheel and 320mm rotors.
All info will be welcome :thumbup:
907IE -91 red/metal grey
907IE -91 red
ansim
Re: 750 Paso front brake adapters to swap 320 rotors to M1R
Post by ansim »
I have made a set for 65mm spacing.
Link to picture: http://alltomingenting.no-ip.info/paso/ ... apter.html
Now with Megasquirt EFI!!
http://www.box.net/shared/lscrqbkkbx
(also with 65mm brakes)
Ansim, the Autocad file download doesn`t work. Can you fix it or send me the file ? I would like to add this info to the downloads if you don`t mind.
ansim
Post by ansim »
Here is the autocad file in Autocad2000 version,
http://alltomingenting.no-ip.info/paso/ ... totype.dwg
NOTE:
This adapter is for orginal Oscam wheel with 280mm rotor and orginal M1R fork.
Sorry for this. Remembered wrong.
Here are link to photos with mounted adapter on my Paso.
http://alltomingenting.no-ip.info/gallery/album04
edit 2008-01-09 09:58: Not Brembo, Oscam
Finnpaso
year: 0
Post by Finnpaso »
Yes, i meant adopters between 320mm normal Ducati rotors / 4 piston Black Brembos(or early "golden line" Brembos) / original 750 M21R fork. :thumbup:
907IE -91 red
ansim
Post by ansim »
It seems to be very tight with a 320 rotor/disc and 16" wheel.
See my pictures with 280 rotor,
It's tight with 4piston Brembo/280 rotor and a bigger rotor/disc will probably make it more tight.
I doubt that a 320 rotor won't fit at all.
But with a 17" wheel it will be ok, as you plan, Finnpaso.
With some measurement the adapter can be modified to fit a 320 rotor/disc.
persempre907
Post by persempre907 »
Finnpaso wrote:Yes, i meant adopters between 320mm normal Ducati rotors / 4 piston Black Brembos(or early "golden line" Brembos) / original 750 M21R fork. :thumbup:
Here there is the conversion to 320 mm. rotors, 40 mm. calipers (Brembos black or earlier goldline) keeping the 16" wheels.
http://www.geocities.com/750paso/paso/4 ... sult12.htm
http://www.geocities.com/750paso/paso/4pbrake/brake.htm
ansim
Post by ansim »
Nope, it's still the 280mm rotors and 16" wheel.
Check these pictures, http://www.geocities.com/750paso/paso/4 ... sult12.htm
But it is not so tight with 40mm spacing calipers.
persempre907
ansim wrote:Nope, it's still the 280mm rotors and 16" wheel.
Yes, it's right, I was mistaking.
They are the stock rotors!!!
Sorry :oops: .
However, it will not to be too hard make the right calipers holes to fit with the 320 rotors.
guys, if you just check what I posted. That`s a M1R fork with 17" wheels, 320mm discs and 65mm Brembos + adapters.
Antti, it seems not clear, do you want to switch to 17" with these brakes or keep the 16" ?
ansim
Post by ansim »
True G. :mrgreen:
They looks great and it is an approved mod :D .
jcslocum
Post by jcslocum »
A,
Can we get an update on the Mega Squirt install???
Finnpaso
year: 0
Post by Finnpaso »
Surely i make same time 17" conversion with original 907 wheels, so i meant 17" Ducati rim. :thumbup:
907IE -91 red
Christian
Post by Christian »
I have done adaptor for M1R forks with 17" wheel and 320 mm rotor.
See http://zattol.com/perso/download_f.html
Bye
________________________
Christian
Paso 750
Monster 900 carbu
999s 2005 Xerox
http://www.zattol.com/perso
Finnpaso
year: 0
Post by Finnpaso »
I mean adpters for OLDER black coloured 4 pistons, or OLDER golden line Brembos WITH 40mm hole distance. Those Yours are for newer calipers...
907IE -91 red
