Are these mounted above or below the triple clamp ? I have some aftermarket parts from LUCAS. You can change the piece between clamp and bar to adjust the height of the bar. (similar to these)Yes i thought about the clipons. They are from a 916 (risers) that part is ok, the only problem now is the tank.
The great advantage from the Paioli fork is that other than other Duc forks it`s one of the few with the same length as the original Paso fork. So when swapping fork the best would be to mount the clipons below the triple clamp othewise you "lose" fork length and the overall geometry will change. I figure that this will be probably less important if you have 17" wheels.
It`s tight, but I think cutting the front edge (and rewelding it if necessary) should be sufficiant. Don`t know about space with the fairings on though.But when the tank does not fit, i will make a new one from carbonfiber and epoxi resin bought in your country.
I don`t think it`s over the top. It`s a nice project and going back to the original fork is always possible.What i'm doing is seriously "over the top", but there's no way back and i like to do the work.
I guess most of us would have 2 or 3 Pasos in the garage if we calculated like thatI chose to do it the hard way and will never do it again (you can buy a second hand 750 paso for it
Here`s my Paioli fork. The 16" Marvic rim is almost covered by the 320mm brake disc
PS: what steering head bearings did you use ?
